This is a guide to replace a malfunctioning keyboard. This guide will teach you how to unscrew your keyboard and remove the ribbon cable to allow you to replace the keyboard.
Place the laptop with the screen facing you and grab the opening tool.
Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
You will feel the popping sensation as it slides along.
Lit up the left side of the small plastic bar at the top of the keyboard.
Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
Lift up the keyboard and pull it toward the screen.
To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
The ribbon mentioned is attached to a ZIF connector, so need to guide through removal from ZIF
Once the ribbon is released the keyboard can be removed .
rename tool with a standard link for easier accessibility
