Toshiba Satellite P205D-S8804 Keyboard Replacement
  1. Toshiba Satellite P205D-S8804 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop with the screen facing you and grab the opening tool.
    • Insert it into the top corner of the keyboard and slide it to the right along the length of the keyboard.
    • You will feel the popping sensation as it slides along.
  2. Toshiba Satellite P205D-S8804 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lit up the left side of the small plastic bar at the top of the keyboard.
    • Be careful when removing it, because you will need to apply a bit of force .
  3. Toshiba Satellite P205D-S8804 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH0 screwdriver to unscrew the 4 screws at the top of the keyboard.
    didn't mention length of screws
    Andy Feng - crwdns2934203:0crwdne2934203:0
  4. Toshiba Satellite P205D-S8804 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the keyboard and pull it toward the screen.
    • The keyboard will still be connected to the motherboard by a ribbon cable.
    "away from your body" might be redundant/confusing
  5. Toshiba Satellite P205D-S8804 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P205D-S8804 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the ribbon cable, push upward on the small tabs located on either side of the ribbon.
    The ribbon mentioned is attached to a ZIF connector, so need to guide through removal from ZIF
  6. Toshiba Satellite P205D-S8804 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the ribbon is released the keyboard can be removed .
Caroline Camp
crwdns2935283:001/30/17crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Baylor, Team 3-2, Whitney Spring 2017 crwdns2935289:0Baylor, Team 3-2, Whitney Spring 2017crwdne2935289:0
BU-WHITNEY-S17S3G2
rename tool with a standard link for easier accessibility
crwdns2942667:0crwdne2942667:0 256
