Toshiba Satellite P105-S6147 RAM Replacement
  1. Toshiba Satellite P105-S6147 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin with the laptop laying down on a flat surface, with the bottom facing up.
  2. Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the device.
    • The battery is located in the bottom, left hand corner of the device.
    • Slide the lock switch to the unlocked position.
    • Slide the release lever towards the unlock switch. The battery should now rotate out of its dock in the laptop.
  3. Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the casing directly above the battery.
    • Use a Phillips #0 screwdriver to remove two 4 mm screws located at the top of the casing.
    • Once the cover is removed the RAM sticks will be visible.
  4. Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to disconnect the tabs from the RAM. The tabs are located on either side of the RAM.
    • Apply light, outward force to the tabs.
  5. Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P105-S6147 RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tool to apply light pressure to the bottom of the upper RAM stick.
    • The RAM stick should come loose and be removable by hand.
    • Repeat the previous steps to remove the lower RAM stick.
Benjamin Wilkinson
crwdns2935283:009/21/18crwdne2935283:0
905 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S1-G2, Friess Fall 2019 crwdns2935289:0University of North Texas, Team S1-G2, Friess Fall 2019crwdne2935289:0
UNT-FRIESS-F19S1G2
crwdns2942667:0crwdne2942667:0 295
