Toshiba Satellite M55-S135 Optical Drive Replacement
  1. Toshiba Satellite M55-S135 Optical Drive Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 Optical Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite M55-S135 Optical Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
  4. Toshiba Satellite M55-S135 Optical Drive Replacement, Optical Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
  5. Toshiba Satellite M55-S135 Optical Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop 180 degrees then tilt the near side up.
    • Push the back side of the optical drive out of the laptop using the plastic opening tool.
  6. Toshiba Satellite M55-S135 Optical Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical drive out of the laptop using your fingers.
  7. Toshiba Satellite M55-S135 Optical Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips 00 screwdriver, unscrew the two 2.50mm screws that connect the metal bracket to the optical drive.
    • Remove the bracket from optical drive.
Yuheng Huang
crwdns2935283:001/28/13crwdne2935283:0
13 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-11, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-11, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G11
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 716
