Toshiba Satellite M55-S135 Keyboard Replacement
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite M55-S135 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite M55-S135 Keyboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
klismann Evora
crwdns2935283:003/12/14crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-7, Cichon Spring 2014 crwdns2935289:0UMass Dartmouth, Team 5-7, Cichon Spring 2014crwdne2935289:0
UMASSD-CICHON-S14S5G7
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 792
