Toshiba Satellite M55-S135 Hard Drive Replacement
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite M55-S135 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
Matthew Trinh
crwdns2935283:001/31/13crwdne2935283:0
63 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-11, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-11, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G11
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - crwdns2934203:0crwdne2934203:0
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,132
