If your Toshiba Satellite L755-S5244 Optical Drive is not reading disks, then it should be replaced. The removal of or the replacement of the optical drive will require this guide.
Before anything start by disconnecting the battery.
Next, unscrew the RAM cover and carefully remove it. Then, locate and unscrew the optical drive screw.
Finally, detach the mounting bracket from the optical drive in order to attach it to the new optical drive then follow the steps in reverse to reassemble it.
