Toshiba Satellite L75-B7270 Drive or RAM Replacement
  1. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide battery locks outward.
    • Remove battery.
  2. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove optical drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove optical drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove optical drive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove screw.
    • Slide out optical drive.
    • Model: UJ8E2 Parts number: G8CC00061Z20
  3. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove bottom cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove bottom cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 16 screws holding the back cover. The screws are all the same length.
    • Remove cover screw that was blocked by optical drive. This screw is a different size.
  4. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Pry off bottom cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Pry off bottom cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Pry off bottom cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the spudger (can use old credit card, ID card, etc.) between seam of the cover.
    • This may be easiest to do near the optical drive.
    • Use the spudger and your fingers to separate the cover around the entire bottom of the laptop, eventually the cover will be free.
  5. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Locate drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Locate drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Locate drive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The drive uses a SATA connector.
    • The drive is kept in place by rubber. There are no screws.
    • The purple box shows the location of the two RAM slots. DDR3L 1600MHz. Maximum of 16 GB.
  6. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Remove drive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift up a rubber blocks; the rubber may be old and where it attaches is thinner. This will give you room to slide the drive.
    • Insert a flathead screwdriver in the gap and slide the drive away from the connector. Do this on both sides.
  7. Toshiba Satellite L75-B7270 Drive or RAM Replacement, Drive images: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L75-B7270 Drive or RAM Replacement, Drive images: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The drive has a rubber case that can be removed and re-used and installed on a replacement drive.
    • The black plastic is the empty drive location.
Jessica
crwdns2935283:004/13/25crwdne2935283:0
370 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 49
