Toshiba Satellite L675D-S7016 Disk Drive Replacement
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L675D-S7016 Disk Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L675D-S7016 Disk Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L675D-S7016 Disk Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
Austin Bons
crwdns2935283:009/22/16crwdne2935283:0
1,131 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-2, Oliver Fall 2016 crwdns2935289:0UC Davis, Team 2-2, Oliver Fall 2016crwdne2935289:0
UCD-OLIVER-F16S2G2
crwdns2942667:0crwdne2942667:0 437
