Toshiba Satellite L55W-C5256 CPU Heatsink Replacement
  1. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement, CPU Heatsink: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L55W-C5256 CPU Heatsink Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
Jennifer
crwdns2935283:009/23/19crwdne2935283:0
777 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team S1-G5, Virtue Fall 2019 crwdns2935289:0Western Carolina University, Team S1-G5, Virtue Fall 2019crwdne2935289:0
WCU-VIRTUE-F19S1G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 226
