This guide will instruct you on how to safely remove and replace the CPU heat sink of your Toshiba Satellite L55W-C5256. You may need to do this if:
- Your device is continually overheating or running hot
- Your device powers down or blue screens due to CPU overheat
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static wrist strap and an anti-static work mat (recommended), see the guide found here.
Flip the laptop over so that the model numbers are facing the ceiling.
Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
Disconnect the battery connector cable from the motherboard.
Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
Lift the battery from the motherboard.
Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
Lift the heat sink from the motherboard.
