This guide should be used if a key is loose on the keyboard or a key isn’t working as intended.
The process should not require any tools, but a plastic opening tool may make it a little easier.
Open laptop in the front facing position.
Use a plastic opening tool to remove the desired key from the keyboard.
Use a finger to push a new key into place.
If the key does not feel like it feels to be in the correct position, retry the process following the steps in order again.
