Toshiba Satellite L505D-GS6000 Disk Drive Replacement
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Adam Dellicker
crwdns2935283:003/19/18crwdne2935283:0
539 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G2, Covino Spring 2018 crwdns2935289:0UMass Dartmouth, Team S4-G2, Covino Spring 2018crwdne2935289:0
UMASSD-COVINO-S18S4G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 467
