Toshiba Satellite L505 Laptop Speakers Replacement
  1. Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Speakers Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement, Optical Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Speakers Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement, Palm Rest Assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Toshiba Satellite L505 Laptop Speakers Replacement, Speakers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Palm rest assembly and flip it over.
    • Locate the 2 speakers.
  12. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws.
  13. Toshiba Satellite L505 Laptop Speakers Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the red and white wires until they join into a plug and disconnect for easy removal of the speakers.
Matias
crwdns2935283:009/26/18crwdne2935283:0
1.028 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S7-G1, Thompson Fall 2018 crwdns2935289:0University of North Texas, Team S7-G1, Thompson Fall 2018crwdne2935289:0
UNT-THOMPSON-F18S7G1
crwdns2942667:0crwdne2942667:0 823
