Removing the keyboard from this laptop is a very simple and easy process. It should be noted that even though it is simple, it is equally as easy to push a component on the hard drive out of place since some parts of the motherboard are exposed under the keyboard
Open the laptop and locate the plastic strip just above the keyboard.
With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
Remove the four screws using the Phillips #1 screwdriver.
Gently push the clip back as you lift the top of the keyboard towards you.
Gently disconnect the connector strip by pushing the white clips forward.
Carefully pull the strip out of its port.
Remove the keyboard from the device.
