The removal of the hard drive is a multi-step process which is simplistic at first glance, but can present a challenge if instructions are not carefully followed.
Turn the laptop upside down.
Unscrew the screw using a Phillips #1 screwdriver.
Lift and remove the cover from the device.
Unscrew the circled screw and set it aside.
With the laptop oriented with the battery at the top, slide the hard drive component to the left until it clicks.
Gently lift up to remove the hard drive from its compartment.
