Toshiba Satellite L455-S5975 WiFi Card Replacement
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the wifi card from the laptop.
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
Dylan Baker
crwdns2935283:003/11/14crwdne2935283:0
188 crwdns2915208:0crwdne2915208:0
UMD team 2 crwdns2935289:0UMD team 2crwdne2935289:0
Community
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,355
