Toshiba Satellite L455-S5975 WiFi Card Replacement
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Laptop into an upside-down position.
    • Push the latches (indicated in red) outwards.
    • Lift the battery by its notch (indicated in orange) in order to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, unscrew the single 7mm screw (indicated in red).
    • Remove the plastic covering, where the screw was removed, using a provided plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the Wifi Card on the left-hand side of the compartment you previously revealed in step 2.
    • Locate the black and white wires. Lift the plastic lever gently to release each wire individually. (A light snapping sound will occur)
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two 6 mm screws at the bottom of the wifi card (indicated in red). Unscrew both, using Phillips #00 screwdriver. Save and store the screws in a safe location.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L455-S5975 WiFi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the wifi card from the laptop as demonstrated in the red circle.
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
Dylan Baker
crwdns2935283:003/11/14crwdne2935283:0
188 crwdns2915208:0crwdne2915208:0
UMD team 2 crwdns2935289:0UMD team 2crwdne2935289:0
Community
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,444
