Toshiba Satellite L45-S7423 Wireless Card Replacement
  1. Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement, Bottom Access Panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement, Wireless Card: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the black and the white antenna wires attached to the wireless card.
    • Using a plastic removal tool, gently pop the connections apart.
  7. Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws holding the wireless card in place.
    • Two 3.6 mm Phillips screws.
  8. Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The wireless card will automatically pop up allowing for easy removal.
  9. Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L45-S7423 Wireless Card Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull to remove the wireless card.
Stephen Sippel
crwdns2935283:004/16/13crwdne2935283:0
194 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-54, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 21-54, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S21G54
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,427
