The LCD display can be easily separated from the laptop body to allow for replacement if it is damaged or functioning improperly.
Make sure the battery lock switch is switched to the unlocked position.
The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
Slide the battery release switch to the left.
Remove the 5 Phillips screws holding the panel in place.
Use a finger to remove the panel by lifting up on the provided removal tab.
Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
Remove the yellow tape holding the black and the white wires in place.
Unwind the wires from the plastic tabs holding the wires in place.
Remove the screw holding the ground cable in place.
One 4.5 mm Phillips screw.
Disconnect the video cable connecting the display to the base of the laptop.
Pop off the laptop's hinge covers using a spudger tool.
Remove the two screws on the back side of the laptop holding the LCD display in place.
Two 8.5 mm Phillips screws.
Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
