Toshiba Satellite L305D-S5950 Fan Replacement
  1. Toshiba Satellite L305D-S5950 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Fan Replacement, Hard Disk Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement, Hard Disk Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To separate the hard drive from the caddy, unscrew the two screws.
  9. Toshiba Satellite L305D-S5950 Fan Replacement, RAM: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement, RAM: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement, RAM: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  10. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  11. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  12. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
  13. Toshiba Satellite L305D-S5950 Fan Replacement, Keyboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement, Keyboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  14. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  15. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  16. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard completely from the laptop.
  17. Toshiba Satellite L305D-S5950 Fan Replacement, Motherboard Cover: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement, Motherboard Cover: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  18. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  19. Toshiba Satellite L305D-S5950 Fan Replacement, Motherboard: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all the screws indicated by the red circles (The bottom two screws are 10.75mm and the top screw is 5mm).
    • Unplug all the wires indicated by the orange squares.
    • Some wires may have a lock on them that needs to be pulled out before the wire is removed.
  20. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • At this point the motherboard can be fully removed from the laptop.
  21. Toshiba Satellite L305D-S5950 Fan Replacement, Fan: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, disconnect the fan power cord from the motherboard.
  22. Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305D-S5950 Fan Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, disconnect the fan from the heatsink.
William
crwdns2935283:003/26/14crwdne2935283:0
889 crwdns2915208:0crwdne2915208:0
Clemson, Team 1-2, Benson Spring 2014 crwdns2935289:0Clemson, Team 1-2, Benson Spring 2014crwdne2935289:0
CLEM-BENSON-S14S1G2
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 937
