Locate the two sliding battery locks on the underside of the laptop.
Locate the right battery lock and slide it to the right.
While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
Locate the RAM cover on the underside of the laptop.
Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
Using your fingers, carefully remove the cover.
