Toshiba Satellite L305-S5875 Hinge Replacement
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close your laptop and flip it over.
    • Remove the 13 screws using a Phillips #00 screwdriver.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  8. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the top case from the bottom case of the laptop.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hinge Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
Tyler
crwdns2935283:003/11/14crwdne2935283:0
208 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-1, Calaway Spring 2014 crwdns2935289:0UMass Dartmouth, Team 3-1, Calaway Spring 2014crwdne2935289:0
UMASSD-CALAWAY-S14S3G1
Will this work for a Toshiba satellite l655 model
ethanhunemuller - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 6,560
