Toshiba Satellite L305-S5875 Hard Drive Replacement
  1. Toshiba Satellite L305-S5875 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over so that you can see the back. Make sure that the volume scroller is closest to you when it is flipped over.
    • Locate the hard drive compartment. This is in the bottom left hand side of the laptop.
    • Remove the two 5 mm type-0 Phillips head screws that secure the door and save them to a safe location.
    • Remove the hard drive cover.
  4. Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the small door removed, find the black ribbon that is attached to the hard drive tray.
    • Carefully pull the ribbon to the left so that the hard drive tray slides out neatly.
  5. Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.2 mm type-0 Phillips head screws located on the side of the hard drive enclosure.
  6. Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite L305-S5875 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive from the tray.
    • Make sure that when you slide the tray back into place, that the ribbon remains easily accessible.
David Zhuo
crwdns2935283:001/11/13crwdne2935283:0
35 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-5, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 20-5, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S20G5
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 2,503
