Use this guide to replace or upgrade the random access memory (RAM) in your Toshiba Satellite L300-04P (PSLB8C-04P01X).
Unlock the battery by sliding the left battery latch to the right.
To remove the battery, hold the spring-loaded right battery latch to the right, then grasp the center battery tab and pull upward.
Use a Phillips #00 screwdriver to loosen the RAM cover captive screw.
Remove the RAM cover.
Simultaneously push the two silver retaining arms apart.
Pull the RAM directly out of its socket.
