The hard drive may need replacement due to a variety of reasons such as malfunction, overuse, etc. This guide will demonstrate how to find, and remove the laptop's hard drive in order for replacement.
Close the laptop and flip it over so that the base is facing upward.
Using the JIS #0 screwdriver tip unscrew all 10, M2X4 size screws holding down the lid.
Using a spudger pry the bottom lid of the laptop from the rest of the laptop.
Remove the yellow tape that connects the battery to the rest of the laptop by simply pulling it off.
Disconnect the indicated cable from the cable connector by gently pulling on it.
Lift up the battery carefully.
The hard drive is connected at the end of the white barcode.
To remove, first pull up on the end of the hard drive opposite of the barcode.
After pulling up on the hard drive, pull in the opposite of the direction of the white barcode.
Excelente tutorial... más especifico no podría ser
Muchas gracias por compartir el conocimiento..
