Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement
  1. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your laptop before continuing.
    • Remove the following two 4mm screws with a Phillips #0 screwdriver.
  2. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery out towards you.
  3. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Bottom Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following twelve 4mm screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to depress the six white clips connecting the plastic cover
  5. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Plastic Cards
    $2.99
    • Run the spudger or a plastic card around the entire laptop to release the rest of the clips.
  6. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cover and set to the side.
  7. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement, Fan/Heatsink: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2mm screws with a Phillips #0 screwdriver.
    • Remove the two 2mm screws with a Phillips #0 screwdriver.
  8. Toshiba Satellite E45t-B4300 Fan/Heatsink Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger or your fingers to disconnect the fan from the motherboard.
    • Remove the fan and heatsink.
Joshua Swanson
crwdns2935283:002/20/17crwdne2935283:0
701 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G2, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team S2-G2, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S2G2
crwdns2942667:0crwdne2942667:0 454
