Toshiba Satellite E45-B4200 RAM Replacement
  1. Toshiba Satellite E45-B4200 RAM Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite E45-B4200 RAM Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite E45-B4200 RAM Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to turn off the device, remove the battery, and unplug the laptop from the charger prior to the disassembly.
    • Use a Phillips #0 screwdriver to remove fourteen 3.75 mm screws from the back cover.
    • Use a spudger or opening tool to gently separate the back cover from the top of the device. Work your way around the perimeter of the laptop and undo the clips with the spudger.
    • Remove the back case.
  2. Toshiba Satellite E45-B4200 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite E45-B4200 RAM Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Underneath the two plastic black flaps you will find the RAM sticks.
  3. Toshiba Satellite E45-B4200 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite E45-B4200 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite E45-B4200 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the RAM from the slot, pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Repeat the instructions for the other RAM slot.
Raymond Makynen
crwdns2935283:003/20/23crwdne2935283:0
289 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-2, Ramos Spring 2023 crwdns2935289:0UMass Dartmouth, Team 5-2, Ramos Spring 2023crwdne2935289:0
UMASSD-RAMOS-S23S5G2
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 586
