Toshiba Satellite Click 2 Pro Motherboard Replacement
  1. Toshiba Satellite Click 2 Pro Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Push down on the tablet sides until you feel a click, then pull up.
    • This will separate the tablet from the detachable base, make sure to hold down the keyboard for easier detachment.
  2. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the base of the tablet from the screen using a plastic opening tool.
    • Make sure to separate the base evenly on both sides when removing it from the screen.
  3. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery power connector using ESD safe tweezers.
  4. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the LED ribbon cable using ESD safe tweezers.
    • Remove the SIM card ribbon cable using ESD safe tweezers.
    • Remove the Docking connector ribbon cable using plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel off gently to prevent damage.
    • Make sure to flip up the white connector attached to the LED and Sim Card ribbons before removing them .
  5. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the LCD Display ribbon cable using a plastic opening tool.
    • Remove the I/O ribbon cable using a plastic opening tool.
    • The ribbons may be stuck to the battery so make sure to peel them off gently to prevent damage.
  6. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
  7. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from its holding position.
  8. Toshiba Satellite Click 2 Pro Motherboard Replacement, Heat Sync Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power connector from the fan using a pair of tweezers.
  9. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3.0mm Phillips J0 screws using a Phillips screw driver.
  10. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 3.5mm Phillips J0 screws from the heat sink.
  11. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink fan.
    • The heat sink cover may be hard to peel off the first time due to the adhesive.
  12. Toshiba Satellite Click 2 Pro Motherboard Replacement, Wifi Card: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
  13. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black and white cables attached using ESD safe tweezers.
  14. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove wifi card.
  15. Toshiba Satellite Click 2 Pro Motherboard Replacement, Motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the five connectors using ESD safe tweezers.
  16. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.0mm Phillips J0 screws using a Phillips screw driver.
  17. Toshiba Satellite Click 2 Pro Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
Paul DeOrsey
crwdns2935283:003/10/16crwdne2935283:0
893 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-3, Catania Spring 2016 crwdns2935289:0UMass Dartmouth, Team 4-3, Catania Spring 2016crwdne2935289:0
UMASSD-CATANIA-S16S4G3
crwdns2942667:0crwdne2942667:0 1,279
