Before you attempt to follow this guide make sure you have all the required tolls needed for the removal of the fan. This may be challenging to be complete. Make sure you follow each step as it is listed.
Push down on the tablet sides until you feel a click, then pull up.
Remove the base of the tablet from the screen using a plastic opening tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the battery power connector using ESD safe tweezers.
Remove the LED ribbon cable using ESD safe tweezers.
Remove the SIM card ribbon cable using ESD safe tweezers.
Remove the Docking connector ribbon cable using plastic opening tool.
Remove the LCD Display ribbon cable using a plastic opening tool.
Remove the I/O ribbon cable using a plastic opening tool.
Remove five 3.5mm Phillips J0 screws using a Phillips screw driver.
Remove the battery from its holding position.
Remove the power connector from the fan using a pair of tweezers.
Remove two 3.0mm Phillips J0 screws using a Phillips screw driver.
Remove four 3.5mm Phillips J0 screws from the heat sink.
