Flip the laptop over so the bottom of the device is facing upward.
Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
Carefully unplug the battery from the device motherboard.
Peel off the black antenna stuck to the card.
Carefully use the PH1 screw head to unscrew the one 3mm screw on the network card found near the hinge at the top.
