Toshiba Satellite C875-S7304 RAM Replacement
  1. Toshiba Satellite C875-S7304 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down laying it onto a flat surface with the battery facing you.
    • The two eject switches are located on the right and left side of the battery compartment.
  2. Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the right switch further towards the right to lock it into place.
  3. Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the switch to the left. Continue to push the switch because unlike the right switch, it will not lock into place.
  4. Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using both hands, continue to push the left switch and grasp onto the center notch located in between the right and left switch.
    • Pull the center notch towards you and you will notice the battery will start to eject.
  5. Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out carefully using two hands.
  6. Toshiba Satellite C875-S7304 RAM Replacement, RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 to unscrew one 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until loosened.
  7. Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the plastic opening tool between the back panel and the hard drive/RAM panel near the screw.
    • Lift the end of the opening tool slowly until the hard drive/RAM panel separates on one side.
    • Repeat the steps above on the left side of the hard drive/RAM panel.
    • Pull the cover towards you and up from the device to remove it.
    • Hearing a popping noise while wedging the plastic opening tool is normal.
  8. Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C875-S7304 RAM Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push outward on the metal tabs to unclasp the RAM from its slot.
    • With the RAM unclasped at a slight angle, carefully pull it out with two hands.
    • When reassembling, remember to align the indentation on the RAM with the indentation on its slot.
Taimoor Arshad
crwdns2935283:009/04/19crwdne2935283:0
408 crwdns2915208:0crwdne2915208:0
University of Alabama, Team S2-G5, Bedsole Fall 2019 crwdns2935289:0University of Alabama, Team S2-G5, Bedsole Fall 2019crwdne2935289:0
UA-BEDSOLE-F19S2G5
crwdns2942667:0crwdne2942667:0 1,335
