Toshiba Satellite C855D-S5303 Disc Drive Replacement
  1. Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C855D-S5303 Disc Drive Replacement, Disc Drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To begin, locate the middle L-shaped panel on the back of the device. Remove the one 7mm long screw (5mm head) located on that panel.
    • Once the screw is removed, lift the panel by grabbing the indentation by the screw and pulling upwards.
    • Be gentle when lifting, the panel could break if you apply too much force.
  2. Toshiba Satellite C855D-S5303 Disc Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the screw to the right of the RAM inside the panel. This screw is 6mm long (5mm head); remove it with a small Phillips head screwdriver.
  3. Toshiba Satellite C855D-S5303 Disc Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C855D-S5303 Disc Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the single screw is removed, you should be able to smoothly slide out the disc drive.
    • Do this by grabbing the tray located on the right edge of your device and pulling out.
Courtney Burns
crwdns2935283:010/20/16crwdne2935283:0
863 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 crwdns2935289:0UMass Dartmouth, Team 2-5, Isaacson Fall 2016crwdne2935289:0
UMASSD-ISAACSON-F16S2G5
crwdns2942667:0crwdne2942667:0 474
