Toshiba Satellite C855D-S5303 Battery Replacement
  1. Toshiba Satellite C855D-S5303 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C855D-S5303 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C855D-S5303 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery can now be pulled out entirely. You are ready to replace it.
Courtney Burns
crwdns2935283:010/20/16crwdne2935283:0
863 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 crwdns2935289:0UMass Dartmouth, Team 2-5, Isaacson Fall 2016crwdne2935289:0
UMASSD-ISAACSON-F16S2G5
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
Rick Walker - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,093
