This is a replacement guide for the keyboard on the Toshiba Satellite C855D-S5109. Replacing the keyboard might be a good option if it is worn and over-used or even if it is too sticky to fully clean. Sonetimes the letters on keyboard keys rub off with time, so it might be a good idea to replace the keyboard when this happens. The guide takes you through the steps to remove and replace the keyboard, such as; removing the battery, carefully prying the keyboard up, and disconnecting the keyboard ribbon cable. When replacing the keyboard it is imperative to exercise caution and practice patience. Be sure the laptop is disconnected from any power source and the battery is removed before attempting to replace the keyboard.
Flip the laptop over so the bottom is facing up.
Slide the two lock tabs on the battery to the open position.
While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
Remove the battery.
Using a Jimmy, slowly lift the keyboard up and away from the palm-rest. Slowly work around the edges, pushing the clips back, prying the keyboard up with minimal force.
Flip up the locking flap of the ZIF connector holding the keyboard cable on the motherboard.
Pull the keyboard ribbon cable out from the connector on the motherboard.
Remove the keyboard from the laptop.
