Toshiba Satellite C855-S5115 Cooling Fan Replacement
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the CPU fan.
Claire Fletcher
crwdns2935283:004/05/18crwdne2935283:0
988 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G4, Johnson Spring 2018 crwdns2935289:0Linn Benton Community College, Team S1-G4, Johnson Spring 2018crwdne2935289:0
LBCC-JOHNSON-S18S1G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,699
