Toshiba Satellite C70D-A RAM Replacement
  1. Toshiba Satellite C70D-A RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off and unplug the charger from your device.
    • Carefully flip your device upside down, laying it on a flat surface with the battery facing you.
  2. Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the two eject switches located on the right and left sides of the battery compartment to release the battery.
    • Gently remove the battery.
  3. Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to loosen the single 7.0 mm screw from the hard drive/RAM panel.
    • You cannot remove the screw from the panel. Simply unscrew it until it is loosened.
    • Pull the cover towards you and up from the device to remove it.
    • If the cover does not come off easily, use an opening tool or spudger to gently pry the cover up.
    • Hearing a snapping noise while removing the hard drive/RAM cover is normal.
  4. Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push outward on the metal arms to release the RAM from its slot.
    • The RAM will pop up by a few millimeters.
    • Remove it at an angle and not straight up so you don't damage the socket.
    • Carefully slide the RAM stick out of the slot.
    • When reassembling, remember to align the indentation on the RAM with the indentation on its slot.
  5. Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the old RAM stick insert the new RAM card.
    • Gently push down on the RAM stick so the metal arms lock around it.
  6. Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace the cover and tighten the screw using the Phillips #1 screwdriver.
  7. Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C70D-A RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the battery back into the laptop.
AYUSH GUPTA
crwdns2935283:007/02/24crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
York University, Team N-14, O'Regan Summer 2024 crwdns2935289:0York University, Team N-14, O'Regan Summer 2024crwdne2935289:0
YORK-O'REGAN-SU24SNG14
crwdns2942667:0crwdne2942667:0 252
