Toshiba Satellite C675-S7106 Keyboard Replacement
  1. Toshiba Satellite C675-S7106 Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Keyboard Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Keyboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
Dinis Valcorba
crwdns2935283:003/26/19crwdne2935283:0
292 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S1G2
crwdns2942667:0crwdne2942667:0 744
