Toshiba Satellite C675-S7106 Hard Drive Replacement
  1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C675-S7106 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the laptop so that the battery cavity faces away from you.
    • Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
    • The screw does not need to be completely removed, as it's permanently attached to the device.
  4. Toshiba Satellite C675-S7106 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C675-S7106 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the existing drive by sliding it towards the left until it's disconnected, and then lift it out of the device.
Dinis Valcorba
crwdns2935283:003/26/19crwdne2935283:0
292 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S1G2
crwdns2942667:0crwdne2942667:0 496
