Toshiba Satellite C675-S7106 CMOS Battery Replacement
  1. Toshiba Satellite C675-S7106 CMOS Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C675-S7106 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0-head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 CMOS Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a thin pry tool, gently remove the battery from its socket.
Joshua Steakelum
crwdns2935283:003/25/19crwdne2935283:0
451 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Simcock Spring 2019crwdne2935289:0
UMASSD-SIMCOCK-S19S1G2
crwdns2942667:0crwdne2942667:0 426
