Toshiba Satellite C655D-S5200 Motherboard Replacement
    • With the battery side facing you, first move the right locking latch to the right.
    • Afterwards, move the left spring latch to the left, but keep your finger there, and pull the battery out with your other hand.
  1. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw securing the hard drive cover to the base.
  2. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive caddy: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw securing the hard drive caddy to the base.
  3. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove hard drive from caddy: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step is unnecessary if you're just removing the hard drive for testing purposes, or to replace the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
    • You're done!
  4. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove some screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twelve "F6"/M2.5x6 screws.
    • Remove the two "F2" screws under where the battery was.
    • Remove the "F3" screw securing the optical drive, and slide the optical drive out.
    • Remove the two "F2" screws from where the optical drive faceplate was.
    • Remove the memory cover screw, pull the memory door open, and remove the two "F6"/M2.5x6 screws from underneath.
    • Use your fingernail or a spudget to get under the keyboard trim, and pry it up. Go along the keyboard trim, pulling it up.
  5. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws securing the keyboard to the palmrest.
    • Lift the keyboard at the top a little, and pull the keyboard towards the screen, so that you see the locking connector below the keyboard.
    • Push the locking connector's lock towards the screen at both the left and the right points, very gently.
    • Pull the now-loose keyboard cable out of the connector.
  6. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove palmrest cables & palmrest: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three palmrest cables from the motherboard, that being the power button cable, the speaker cable, and the touchpad cable.
    • No need to remove any of the other cables yet.
    • Use a spudger to separate the palmrest from the base.
  7. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan cable.
    • Remove the two silver-colored fan screws.
    • Remove the single black-colored fan screw.
  8. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw securing the motherboard to the base.
    • Remove the two wireless antenna connectors.
    • Remove the LCD cable.
    • Lift the motherboard out of the base.
  9. Toshiba Satellite C655D-S5200 Motherboard Replacement, Remove the heatsink: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws securing the heatsink to the motherboard.
    • Remove the processor, memory, and optionally, the clock battery. Install the first two in the replacement motherboard. You're done!
Joseph Sctbunio
crwdns2935283:009/23/17crwdne2935283:0
7,578 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
is there any processor upgrades compatible with this specific computer? other than ram and ssd any upgrade info would be appreciated.
robert wallace - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 3,247
