Typical Toshiba and no service manuals available. The LCD on this laptop was removed for other purposes. This is a straight forward task and only requires minimal tools.
Here is the Toshiba Satellite C655D-S5200
Open the laptop with the LCD facing forward. There are four rubber caps, one in each corner
Removing the plugs reveal the Phillips screws
Remove all four screws, tow on top left and right corner
One on the bottom left corner
and the bottom right corner.
Here are the four M3x5mm screws
Use a plastic opening tool, or similar to pop the bezel of the LCD assembly
Continue to slide the tool all the way across the top
Once the bezel has been released from the tabs, it can be further released be applying some gently manual pulling
Continue to pull gently on the sides
and finally on the bottom.
With all the tabs released the bezel can now be removed.
Here is the LCD assembly without the bezel
Remove the Phillips screw that connects the LCD frame to the back cover. This is the left one
Remove the right one as well
The LCD can now be moved forward and away from the rear cover
There are three screws on either side that hold the panel to the frame. Remove those
Here are the three M2x4 screws
Remove the three Phillips screws on the right side as well.
with the screws removed the panel can now be moved out of the LCD frame. The LCD is still connected by the display cable.
The display cable is secured to the connector with some clear adhesive. Remove this frist
Remove the display cable carefully.
With the display cable disconnected, the LCD can now be removed and replaced.
