Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
Shelby Kunz
crwdns2935283:004/19/13crwdne2935283:0
69 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 2-20, Maness Spring 2013 crwdns2935289:0Cal Poly, Team 2-20, Maness Spring 2013crwdne2935289:0
CPSU-MANESS-S13S2G20
crwdns2942667:0crwdne2942667:0 3,248
