Is your computer running slow? Just need some more space? In this installation guide we are going to take you through the steps to install Random Access Memory (RAM) in your Toshiba Satellite C655D-S5084.
Turn the laptop over and place upside down on a flat surface.
Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
Grip the edge of the card and slide the RAM module out by pulling horizontally.
