This guide will show users how to replace the Toshiba Satellite C55Dt-A5306 disc drive.
Place fingers on the latches and slide outwards to unlock.
Using the Phillips Head #0 Screwdriver, remove one 3mm Phillips #0 screw as indicated.
Remove hard drive cover. Using the Phillips Head #0 Screwdriver, remove seven 3mm Phillips #0 screws as indicated.
Using the Phillips Head #0 Screwdriver, remove twelve 3mm Phillips #0 screw as indicated.
Using the plastic spudger, pry the back off along the periphery of the laptop.
Slide the disc drive to the left. It should come off with ease.
crwdns2917034:0crwdne2917034:0
Change the title to say "optical drive," rather than "disc drive." I was fooled while looking for instructions on removing the hard drive.
