Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the fan and heat sink away from the motherboard.
Laura Tamayo
crwdns2935283:002/14/19crwdne2935283:0
678 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Leahy Spring 2019 crwdns2935289:0USF Tampa, Team S1-G4, Leahy Spring 2019crwdne2935289:0
USFT-LEAHY-S19S1G4
My Toshiba laptop shut down exactly after 30 minutes why is the reason? Please tell me the problem & the solution.
Afetes - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 464
