If the hard drive in your laptop begins to make a loud clicking noise known as "the Click of Death", use this guide to remove and replace your hard drive.
Flip the laptop over so the model stickers face the ceiling.
Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery.
Carefully slide the battery out of the laptop.
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Slide the CD/DVD Drive out of the laptop.
Use a Phillips #1 screwdriver (PH1 bit) to remove the thirteen 7 mm screws that secure the bottom cover.
Use a plastic opening tool to separate the back cover from the laptop.
Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
Remove the hard drive from the blue rubber mount.
