If the fan is excessively noisy or non-operational, use this guide to remove and replace the fan.
Flip the laptop over so the model stickers face the ceiling.
Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery.
Carefully slide the battery out of the laptop.
Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Using the plastic opening tools, separate the back cover from the laptop.
Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
Lift the fan cable connector from the fan.
Remove the fan from the plug by releasing the clamps located on each side of the socket.
Slide the connector out of the socket.
Lift the computer fan from the motherboard.
