If the battery has failed or not charging, use this guide to replace.
Flip the laptop over so the model stickers face the ceiling.
Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery.
Use your phillips screwdriver to begin removing all the accesible screws.
Now begin to remove the coverings above and below the middle plate with your hand.
use your hand or a tool to remove the tabbing on the metal plate covering the battery.
Remove the metal plate covering the battery.
Use your wedging tool to begin removeing the adhesive under the battery.
