Toshiba Satellite C55D-B5206 Hard Drive Replacement
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite C55D-B5206 Hard Drive Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
Michelle
crwdns2935283:009/17/15crwdne2935283:0
175 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-5, Bruce Fall 2015 crwdns2935289:0CSU Fullerton, Team 2-5, Bruce Fall 2015crwdne2935289:0
CSUF-BRUCE-F15S2G5
crwdns2935297:018crwdne2935297:0
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 5,075
